When I export the CD sleeve to a file (tried JPG/BMP/TIFF, all same result, as I want to include in an Email) the sleeve that I saved does not print at CD sleeve size but about an inch bigger? I've tried a lot of stuff to fix but alas, no luck
When using the "Save as Image" or "Export Label to Image File" option in AudioLabel, there is an option to set the DPI (dots per inch) of the image file being saved. The DPI is embedded into the image file.
In order to print the image to scale, the program you are using to print MUST take into account the DPI.
