Windows 11, Windows 10,
Windows 8.1, Windows 8,
Version: 7.0 Build 7
File Size: 10.6 MB
Canon MG6350 Direct CD Printer Template included in V-5.00
Postby Admin » Sun Feb 10, 2013 2:44 pm
UPDATE* 04/10/2013 - AudioLabel 5.00 (Build 6) now includes the Canon MG6350 Direct CD Printer template, so there is no need to make a custom template.
We received an inquiry about printing directly on a disc using a Canon MG6350 printer. I'm posting the response on our forum in case other folks have the same question.
You can print directly on the disc in AudioLabel using the Canon MG6350; although, you will need to make a custom template.
Please go to the "Change Label Template" dialog and then click the "Create New" button. From there, enter "Canon MG6350" for the Name, select "Milimeters" for your Units, and also select "CD/DVD Printer" for your Paper Size. Then enter the following dimensions for the disc:
Left: 6.12 mm
Top: 60.86 mm
Outer Diameter: 118.0 mm
Inner Diameter: 41.0 mm
You should adjust the "Inner Diameter" to the actual hole size of your ink jet printable disc. Next "Save" your template and make sure it is selected in the "Change Label Template" dialog. From this point, printing should be straight forward; although, it's always recommended that you test print on a scrap disc before using the real deal.
Re: Canon Printer MG6350
Postby Admin » Wed Apr 10, 2013 6:58 pm
AudioLabel 5.00 (Build 6) now includes the Canon MG6350 Direct CD Printer template, so there is no need to make a custom template. This is a free update for all those who own AudioLabel version 5.00, or have purchased AudioLabel within the last year.
Re: Canon MG6350 Direct CD Printer Template included in V-5.
Postby jagjockey » Sat Nov 30, 2013 4:33 am
I have gone all thru the process of putting an image on the template but it still only prints on paper rather than direct to cd.
Any help would be appreciated.
Regards,
Al.
jagjockey
Postby Admin » Sat Nov 30, 2013 12:02 pm
I'll be glad to help.
When trying to print directly on the disc, sometimes the printer prints on paper instead of the inkjet printable disc. This a common problem, but it always corrected with the right print driver settings.
We just need to verify a few things before continuing:
1. What version and build of AudioLabel are you are using? (example - Version 5.0 Build 7)
2. Are trying to print directly on a CD using the Canon Pixma MG6350 printer?
3. Which Windows operating system are you using? (i.e. Windows 8, Windows 7, Vista, XP)
