by » Fri Aug 02, 2013 2:12 am
Hi Dave,
The Neato CLP-192301 label paper has 3 disc labels per page. Currently, AudioLabel only supports 2 disc labels per page, but you can still make it work. You basically need to create 2 custom templates in AudioLabel (1 template for the first 2 discs, and 1 template for the third disc). The label paper will need to be run through the printer twice in order to print on all 3 discs.
You can add a custom template in AudioLabel by going to the "Change Label Template" dialog and clicking the "Create New" button under "Disc Labels".
The first custom template should have the following information:
Name: Neato CLP192301 - Template 1
Units: Millimeters
Paper Size: Letter
Left (1): 6.4 mm
Top (1): 6.4 mm
Left (2): 94.5 mm
Top (2): 82.0 mm
Outer Diameter: 114.8 mm
Inner Diameter: 41.3 mm
The second custom template should have the following information:
Name: Neato CLP192301 - Template 2
Units: Millimeters
Paper Size: Letter
Left (1): 94.5 mm
Top (1): 82.0 mm
Left (2): 6.4 mm
Top (2): 158.2 mm
Once these templates are created, you can select them in the "Print" dialog and your label designs will automatically switch between the different disc positions. We will be adding support for 3 discs per page in a future release, but hopefully this solution will work for you. Please let me know if you have any questions.
