Neato 3up Template for CLP-192301, OL9325, SL113
Postby whodart » Wed Jul 31, 2013 1:05 pm
Hi group. I have quite a few of these 3 disc labels and now I can't seem to find a way to use them with my Audiolabel 5 now. How can I incorporate the label type with the proper dimensions? Thanks
Dave E :roll:
whodart
Re: template for clp192301, ol9325, sl113 dvd label
Postby Admin » Fri Aug 02, 2013 2:12 am
Hi Dave,
The Neato CLP-192301 label paper has 3 disc labels per page. Currently, AudioLabel only supports 2 disc labels per page, but you can still make it work. You basically need to create 2 custom templates in AudioLabel (1 template for the first 2 discs, and 1 template for the third disc). The label paper will need to be run through the printer twice in order to print on all 3 discs.
You can add a custom template in AudioLabel by going to the "Change Label Template" dialog and clicking the "Create New" button under "Disc Labels".
The first custom template should have the following information:
Name: Neato CLP192301 - Template 1
Units: Millimeters
Paper Size: Letter
Left (1): 6.4 mm
Top (1): 6.4 mm
Left (2): 94.5 mm
Top (2): 82.0 mm
Outer Diameter: 114.8 mm
Inner Diameter: 41.3 mm
The second custom template should have the following information:
Name: Neato CLP192301 - Template 2
Units: Millimeters
Paper Size: Letter
Left (1): 94.5 mm
Top (1): 82.0 mm
Left (2): 6.4 mm
Top (2): 158.2 mm
Once these templates are created, you can select them in the "Print" dialog and your label designs will automatically switch between the different disc positions. We will be adding support for 3 discs per page in a future release, but hopefully this solution will work for you. Please let me know if you have any questions.
Re: Neato 3up Template for CLP-192301, OL9325, SL113
Postby whodart » Fri Aug 02, 2013 7:32 am
Thanks, Nicole. I'll set these up and give it a whirl. I see the way you have it laid out template 1 includes top and right, template 2 includes right and bottom. Regards
Dave E
Arkansas :D
whodart
Postby whodart » Sat Aug 03, 2013 3:49 pm
whodart Wrote:Thanks, Nicole. I'll set these up and give it a whirl. I see the way you have it laid out template 1 includes top and right, template 2 includes right and bottom. Regards
Dave E
Arkansas :D
Hi again Nicole. OK, I got the two templates incorporated and adjusted. Had to fine tune the dimensions to work with myh HP352 printer but only took about 6 sheets of plain paper to get the outlines to match up with the label paper. Thanks again.
Dave E
whodart
