Canon iP7250 - Not printing in middle of CD
Postby jvh » Fri Dec 19, 2014 6:44 pm
I have a canon ip7250 when i print on a cd on the screen the print is totally on the cd but when i print it only prints on a part and the rest keeps white.
It is as if the print is not in the middle of the cd.
jvh
Re: not printing on the middle of a cd
Postby Admin » Sat Dec 27, 2014 10:17 am
Please make sure your have selected the "Canon Pixma iP7250 Printer" template in the "Change Label Template" window of AudioLabel.
When your image is printed on the disc, how far off is the image (in inches or millimeters)?
You can adjust the print alignment dimensions in the "Edit Dimensions" window. For example, if the image prints 0.25 inches to the left, you can add 0.25 inches to the "Left" option in the "Edit Dimensions" window. You can also adjust outer diameter of the disc, and the inner diameter of the center hole.
