Greek Language Problem
Do you have other questions about AudioLabel? Post them here!
Postby marouskoni » Sun Jun 16, 2013 3:58 am
HI!
I download the trial versio but when i start to write in a project i select arial but i see arabic.......my language is greek and normaly arial or times new roman works fie. I tried many times but also the same problem. fonts are different
thank you! :?
marouskoni
Re: LANGUAGE PROBLEM
Postby Admin » Wed Jun 19, 2013 2:30 pm
Its sounds like AudioLabel is having a problem loading the "Arial" font. Anytime there is a problem loading a font, AudioLabel will chose the next available font (which could explain why you see Arabic).
This problem might have to do with Greek characters in the font name. Currently, AudioLabel supports the ASCII character set, but does not support the Unicode character set (which is required to fully support all Greek characters).
When you select the "Arial" font in AudioLabel, is the font listed as "Arial", or does the font name have Greek characters in it?
