Hi Jaleb,
It looks like you have selected the correct template in AudioLabel (Epson Artisan 835 Printer).
The correct dimensions should be:
Top: 8.5mm
Left: 16.5 mm
I know how uncomfortable it is to waste printable discs, but you should be able to get the alignment with a little trial and error. Once you get the exact dimensions, you should not have to mess with this again.
Here are some steps I would take to get the correct alignment.
Start with a blank disc template:
- Blank Design.png (Viewed 3175 times)
Add a single piece of text to the label so you know where the top of the disc is.
Next print to the disc with the "Print Border" option turned on:
- Print Border.png (Viewed 3175 times)
After printing the disc you should see the disc border printed on the disc. From here measure how far the disc outline is from the edge. You can then edit the Left and Top dimensions of the Epson Artisan 835 Printer template based on these measurements. Repeat this process until perfect (you can probably use the same testing disc a few times).
