Fold and cut lines for the cover not printing
Postby Mick1954 » Sat Mar 15, 2014 8:26 am
I have version 5.0 and Windows 7. I used to be able to print the fold and cut lines but they will not print at this time. I just downloaded the full version again and still getting the blue lines as if they are hidden. Any ideas? Also the fold and cut lines are selected in the border portion of the custom template.
Mick1954
Re: Fold and cut lines not printing
Postby Admin » Sat Mar 15, 2014 1:03 pm
We just tested the borders and fold line option in AudioLabel version 5.0 (Windows 7) and could not find a problem.
If you cannot see the printed border or fold line, then there might be a problem with your black ink cartridge or the print driver.
What model printer are using?
Postby Mick1954 » Sun Mar 16, 2014 8:11 am
I attached my template for the back cover, please try to print with cut and fold lines and let me know if it works for you.
Template back cover.aud
(14.85 KiB) Downloaded 12054 times
Mick1954
Postby Mick1954 » Tue Mar 18, 2014 2:36 pm
I am using a HP Photosmart Premium C410 series. All ink levels are at a usable level and when I print a sample cover the text shows up in black but no lines. The template label I am using is the (No Background) from the template listing on the right side of the program window. I can see the lines in the template, they are a light blue and thin, not black,
Mick1954
Postby Admin » Wed Mar 19, 2014 11:44 am
The "Print Preview" in AudioLabel shows exactly what is sent to the printer (regardless of the printer or print driver). I downloaded your AudioLabel project file (Template_back_cover.aud), and attached screen shots of the "Print Preview" below. The first image shows the Print Border+Fold Lines option selected, and the second image shows the No Border option selected.
When you print with the Print Border+Fold Lines option turned on, do you see the same image?
Print Borders + Fold Lines
No Border
Postby Mick1954 » Thu Mar 20, 2014 9:43 am
Thank you very much for your patience and time, problem solved.
Mick1954
Re: Fold and cut lines for the cover not printing
Postby DerekWilliamsMusic » Wed Dec 27, 2023 8:39 am
How was it solved? I am not seeing Print or Folder Border lines in either Preview or the output, and I can't upload the image here because it doesn't accept PNG.
DerekWilliamsMusic
Postby DerekWilliamsMusic » Wed Dec 27, 2023 8:44 am
DerekWilliamsMusic
